I undestand, and it’s not a problem when the device is in integration/test of a new/modified DDF. But when the device is already used by some automation it could be a challenge that we don’t have a way to just delete a sensor with -FF endpoint for instance.
My comment was not a working mode ^^.
There is clearly a problem (and a mystery) for me too.
Another occurence : Tuya Soil Sensor · Issue #6731 · dresden-elektronik/deconz-rest-plugin · GitHub and this one had never been picked up by legacy code before having DDF.
Ha yes righ, it’s a temperature sensor, and end device, so without the DDF it could not be included before the DDF installation.
Another case of FF endpoint : LiXee ZLinky_TIC DDF File
Got another one, for a no more existing sensor :
"32": {
"reachable": false
"etag": "523ca834cfae0bd9ea79d5d7b44e7538",
"lastannounced": null,
"lastseen": "2023-02-17T03:00Z",
"manufacturername": "sengled",
"modelid": "E1C-NB7",
"name": "Puissance ventilo projecteur",
"current": 0,
"lastupdated": "2023-02-17T03:01:00.106",
"power": 0,
"voltage": 0
"swversion": "0.1.10",
"type": "ZHAPower",
"uniqueid": "b0:ce:18:14:03:6b:cf:99-ff-0b04"
And that is still in DB (only into sensors table) with
{"lastupdated":"2023-02-17T03:01:00.106","power":0}
It’s your network ?
Let me guess, you have a bind for the cluster 0x0b04 in the bind table and not device in the DDF core ?
Ye it is. And it’s quite the opposite deconz-rest-plugin/devices/sengled/e1c-nb7.json at master · dresden-elektronik/deconz-rest-plugin · GitHub
0x0b04 in core DDF but no bind ! Uneeded because this cluster is unused in core, because it doesn’t exist in the device
And a device that have been deleted for a while …
And it have added power+current+tension that are not present in the DDF …
