Adding custom xml files (ZCLDB)
I am trying to add my own xml-file to extend the general.xml with custom definitions.
The deCONZ user manual shows how to do it but I don’t see any changes in the GUI when I load my file. I think I am doing something wrong. What am I missing?
Writing directly into general.xml works.
Can someone help or does anyone have a sample file?
I’m trying to do the same thing because new .xml loading seems “dynamic”. Once you click to “ok” the XML files are loaded (can view it in debug with just ZCLDB checkbox activated.
But even without error at loading it seems that it doesn’t change anything in GUI.
Or I also miss something
Here is he file I use that is loaded without error. As described in documentation it’s supposed to superseed already existing parts and (i hoped) adding other parts that are not declared in general.xml. But it doesn’t.
<?xml version="1.0" encoding="UTF-8"?>
<zcl>
<domain name="Manufacturer Specific" useZcl="true" description="Manufacturer specific clusters.">
    <!-- SINOPE -->
    <cluster id="0xff01" name="Sinope specific" mfcode="0x119c">
      <description>Sinope specific cluster attributes</description>
      <server>
	<attribute id="0x0002" name="Keypad lock" type="u8" mfcode="0x119c" access="rw" required="m">
	  <value name="Unlocked" value="0x00"></value>
          <value name="Locked" value="0x01"></value>
	</attribute>
	<attribute id="0x0010" name="Outdoor Temp on Display" type="s16" mfcode="0x119c" access="rw" required="m"> <description>Celcius * 100</description> </attribute>
	<attribute id="0x0011" name="Outdoor Temp on Display Timeout" type="u16" mfcode="0x119c" access="rw" required="m">
		<description>Delay in seconds before reverting to setpoint display if no more outdoor temp is received</description>
	</attribute>
	<attribute id="0x0012" name="Config 2nd Display " type="enum8" mfcode="0x119c" access="rw" required="m">
			<value name="Auto" value="0x00"></value>
			<value name="Setpoint" value="0x01"></value>
		        <value name="Outside Temp" value="0x02"></value>
	</attribute>
	<attribute id="0x0020" name="Current Time on Display" type="u32" mfcode="0x119c" access="rw" required="m">
		 <description>Seconds since year 2000</description>
	</attribute>
	<attribute id="0x0050" name="On Led Color" type="u24" mfcode="0x119c" access="rw" required="m">
	  <value name="Lim" value="0x0affdc"></value>
          <value name="Amber" value="0x000a4b"></value>
	  <value name="Fushia" value="0x64ffff"></value>
	  <value name="Perle" value="0x000a4b"></value>
	  <value name="Blue" value="0xffff00"></value>
	</attribute>
	<attribute id="0x0051" name="Off Led Color" type="u24" mfcode="0x119c" access="rw" required="m">
	</attribute>
	<attribute id="0x0052" name="On Led Intensity" type="u8" mfcode="0x119c" range="0,100" access="rw" required="m"> </attribute>
	<attribute id="0x0053" name="Off Led Intensity" type="u8" mfcode="0x119c" range="0,100" access="rw" required="m"> </attribute>
	<attribute id="0x0054" name="Unknown" type="u8" mfcode="0x119c" access="rw" required="m"> </attribute>
	<attribute id="0x0055" name="Min Intensity" type="u16" mfcode="0x119c" range="0,3000" access="rw" required="m"> </attribute>
	<attribute id="0x0060" name="Connected Load" type="u16" mfcode="0x119c" access="r" required="m">
		<description>Watt/hr</description>
	</attribute>
	<attribute id="0x0070" name="Current Load" type="bmp8" mfcode="0x119c" access="r" required="m">
	</attribute>
	<attribute id="0x0071" name="Eco Mode" type="s8" mfcode="0x119c" range="-100,100" default="-128" access="rw" required="m">
		 <description>Eco mode in percent</description>
	</attribute>
	<attribute id="0x0072" name="Eco Mode 1" type="u8" mfcode="0x119c" range="0,99" default="255" access="rw" required="m"> </attribute>
	<attribute id="0x0073" name="Eco Mode 2" type="u8" mfcode="0x119c" range="0,100" default="255" access="rw" required="m"> </attribute>
        <attribute id="0x0076" name="drConfigWaterTempMin" type="u8" mfcode="0x119c" access="rw" required="m"> <description>45 or 0</description></attribute>
        <attribute id="0x0077" name="drConfigWaterTempTime" type="u8" mfcode="0x119c" access="rw" required="m"> </attribute>
	<attribute id="0x0078" name="drWTTimeOn" type="u16" mfcode="0x119c" access="r" required="m"> </attribute>
	<attribute id="0x00A0" name="Timer" type="u16" mfcode="0x119c" access="rw" required="m"> <description>Number of seconds</description> </attribute>
        <attribute id="0x0105" name="Floor Control Mode" type="enum8" mfcode="0x119c" access="rw" required="m">
          <value name="Ambient" value="0x01"></value>
          <value name="Floor" value="0x02"></value>
        </attribute>
	<attribute id="0x0106" name="Aux Output Mode" type="enum8" mfcode="0x119c" access="rw" required="m">
			<value name="Off" value="0x00"></value>
			<value name="Expansion module" value="0x01"></value>
	</attribute>
	<attribute id="0x0108" name="Ambient Max Heat Setpoint Limit" type="s16" mfcode="0x119c" access="rw" required="m">
			<description>temp: celcius*100, valid only if floor control mode is selected</description>
	</attribute>
        <attribute id="0x0109" name="Floor Min Heat Setpoint Limit" type="s16" mfcode="0x119c" access="rw" required="m"></attribute>
        <attribute id="0x010A" name="Floor Max Heat Setpoint Limit" type="s16" mfcode="0x119c" access="rw" required="m"></attribute>
        <attribute id="0x010B" name="Temperature Sensor" type="enum8" mfcode="0x119c" access="rw" required="m">
          <value name="10k" value="0x00"></value>
          <value name="12k" value="0x01"></value>
        </attribute>
        <attribute id="0x010C" name="Floor Limit Status" type="enum8" mfcode="0x119c" access="r" required="m">
	  <value name="floorLimitLowReached" value="0x01"></value>
	  <value name="floorLimitMaxReached" value="0x02"></value>
	  <value name="floorAirLimitMaxReached" value="0x03"></value>
        </attribute>
        <attribute id="0x0114" name="Time Format on Display" type="enum8" mfcode="0x119c" access="rw" required="m">
          <value name="24h" value="0x00"></value>
          <value name="12h" value="0x01"></value>
        </attribute>
        <attribute id="0x0115" name="GFCi Status" type="enum8" mfcode="0x119c" access="r" required="m">
          <value name="Ok" value="0x00"></value>
          <value name="Error" value="0x01"></value>
        </attribute>
	<attribute id="0x0118" name="Aux Connected Load" type="u16" mfcode="0x119c" default="0xffff" access="r" required="m">
		<description>watt/hr, 0xffff=off</description>
	</attribute>
	<attribute id="0x0119" name="Connected Load" type="u16" mfcode="0x119c" access="r" required="m">
		<description>Watt</description>
	</attribute>
	<attribute id="0x0128" name="Pump protection" type="enum8" mfcode="0x119c" access="rw" required="m">
					<value name="Off" value="0xff"></value>
					<value name="On" value="0x01"></value>
	</attribute>
	<attribute id="0x012D" name="Report Local Temperature" type="s16" mfcode="0x119c" access="r" required="m">
	</attribute>
	<attribute id="0x0283" name="ColdLoadPickupStatus" type="u8" mfcode="0x119c" access="r" required="m"> </attribute>
      </server>
      <client>
      </client>
    </cluster>
</domain>
</zcl>
On debug view we can see that the additional file is loaded just after clicking “Ok” on “Preferences” screen
09:14:46:657 void deCONZ::ZclDataBase::load(const QString&) reading file /home/pi/.local/share/dresden-elektronik/deCONZ/sinope.xml
But nothing changes on GUI, even after a restart of DeCONZ.
did you find the solution to have a custom general.xml file please?
Unfortunately not ! Didn’t try anymore after that.
Without copying the complete file into the personal folder, I don’t know how to create a working xml file either. It’s a shame
