Access one Conbee coordinator with two different systems
i am running a Home Assistant instance on a RPI4 and connect to deCONZ through the deCONZ integration. In addition i am running a Home Assistant test system as VM on a QNAP NAS where the Conbee coordinator is connected to and with this test system i like to use Conbee with zigbee2mqtt Integration of Home Assistant.
Is i possible to use one coordinator with two different instances / solutions like the above described environment or does it lead to errors and is not advisable?
Thank you in advance for your advice and support!
Yes you can run multiple clients towards one Deconz instance. That’s how I have it when I work on the Home Assistant integration, my dev machine is separate from my production but both connect to the same Deconz instance.
Thank you for that quick reply!
