WOOX R7049 smoke detector
Ha yep, to have the support using DDF instead of legacy code.
I have check all already present device that look like this one (using the tuya cluster), but they are different, so realy need a new DDF (and Woox have it’s own folder for device)
Are you sure you need the “tuya bind” (at the end), most of tuya device have it natively.
Already present DDF can have problem too ^^ (I have see some “possible useless” code inside)
