Hi guys,
Saw that with the RakTak ⋅ v2.15.0 beta you can try Aqara roller shades and immediately wanted to give it it a try, however… cant find a deCONZ_ConBeeII firmware here: Index of /deconz-firmware/beta/
Any advice?
Thanks!
Hi guys,
Any advice?
Thanks!
Hello firmware and deconz version is no the same thing.
You can find deconz beta version for exemple here for rapberry Index of /raspbian/beta/
Or you can switch to beta branch and just use
sudo apt upgrade
Thanks but that does not work for my setup
I update the stick via Windows machine, so need the firmware file to flash it.
You don’t need the firmware, as raktak is not firmware.
You need this
https://deconz.dresden-elektronik.de/win/deCONZ_Setup_Win32_V2_15_00.exe
Wow, I thought that integration I’ve been using in home assistant with Deconz is relying on the stick firmware.
Are you saying that the plug-in inside home assistant needs to be patched with beta instead?
The addon? Yes.
In that case you can’t as the ha addon only does stables.
Huh. Cool thanks! Is there any compatibility list between the add-on and the Conbee stick firmware?
How’d you mean?
