Unable to update my firmware on RaspBeeII [CLOSED]
Describe the bug
I’m trying to update the firmware of a raspbee II device from 26660700 to 26720700 version on a raspbian system
 $ sudo GCFFlasher_internal -l
Path             | Vendor | Product | Serial     | Type
/dev/ttyS0       | 0x0000 | 0x0000  |            | RaspBee
$ sudo GCFFlasher_internal -r
deCONZ firmware version 26660700
Bootloader version 0x00030003, app crc: 0x5CBFD214
 $ sudo systemctl stop deconz
 $ sudo GCFFlasher_internal -t 60 -f ./deCONZ_ConBeeII_0x26720700.bin.GCF
action: reset device RaspBee
wiringPi 2.52 initialized
retry, failed
Expected behavior
Firmware upgrades
Screenshots
NA
Environment
 $ lsb_release -a
No LSB modules are available.
Distributor ID: Raspbian
Description:    Raspbian GNU/Linux 10 (buster)
Release:        10
Codename:       buster
 $ uname -a
Linux sk4mc 5.10.63-v7l+ #1459 SMP Wed Oct 6 16:41:57 BST 2021 armv7l GNU/Linux
  • Host system: Raspberry Pi 4
  • Running method: Raspbian
  • Firmware version: de26660700
  • deCONZ version: 2.12.06-raspbian-buster-stable
  • Device: RaspBee II
  • Do you use an USB extension cable: (yes / no) – only relevant for ConBee I/II
  • Is there any other USB or serial devices connected to the host system? If so: Which? Yes, USB HD with the system installed on it
Probably nothing to see but deCONZ_ConBeeII_0x26720700.bin.GCF is not a firmware for conbee 2 ? There is some firmware with “RaspbeeII” in name.
I’m really ashamed… I’m too dum :stuck_out_tongue: with the right firmware it works. :smiley: thank you
