20:13:38:335 Device TTL 6481 s flags: 0x7
20:13:42:969 Hot reload device: a4:c1:38:12:4b:70:f8:64
20:13:42:971 Hot reload device: a4:c1:38:1a:06:1c:d7:88
20:13:42:972 Hot reload device: a4:c1:38:fd:e3:48:8a:0b
20:13:42:973 Hot reload device: a4:c1:38:b9:e6:fd:f5:c0
20:13:42:975 Hot reload device: a4:c1:38:8e:20:9a:6a:ef
20:13:42:976 Hot reload device: a4:c1:38:e6:22:1d:a4:5a
20:13:43:057 DEV found DDF for 0xA4C138124B70F864, path: /data/.local/share/dresden-elektronik/deCONZ/devices/door_magnetic_sensor.json
20:13:43:066 DEV found DDF for 0xA4C1381A061CD788, path: /data/.local/share/dresden-elektronik/deCONZ/devices/door_magnetic_sensor.json
20:13:43:074 DEV found DDF for 0xA4C138FDE3488A0B, path: /data/.local/share/dresden-elektronik/deCONZ/devices/door_magnetic_sensor.json
My deconz version is 6.16.0, the last one i suppose.
I don’t have created the DDF, the UI create them. It’s very complicated because I notice that sometimes when i change properties in UI, the DDF don’t update, it’s seems to be very instable. (Raspberry Pi)
Can I take one of two officials DDF directly by copy paste from /usr ?
How to access to the files, in ssh ?
With the raspberry the ssh add-on don’t give access to this directory.
Can you check your deconz version, in phoscon ?
But yes I think the HA plugin use the last one.
The 2 other DDF are already in deconz, so when you have done “edit DDF”, the editor should have take one of them, and not create a new one. You realy have nothing to do.
It’s complicated with the HA OS, but if you have a recent version, you need to have them natively, one of them is 3 month old.
Just delete the one you have saved(" door_magnetic_sensor.json) and BTW you have this file “permanent”, it don’t disapear if you restart deconz ?
Deconz at start parse all your DDF, and use one that match your device.
So if you delete the incomplete one, it will use on of the working one. There is no affectation, but a new scan at every restart.
I think you have used the “edit DDF” feature so deconz have created a basic DDF but incomplete and you have saved it.
And your custom DDF are prioritary on deconz official one.
I didn’t really understand how DDFs worked, but now everything works, but also I know a bit more about how it works. Thanks a lot ! The issu can be closed.
