Suddenly no connection to zigbee network. Even with different stick or reinstall
I am a bit desperate and hope someone can help me here.
I have deconz / phoscon running on a raspi 4 with iobroker. A few days ago all my zigbee devices suddenly stopped working. I tried restarts, loaded a backup via phoscon, than I tried to load some older zigbee configs ( Network lost issues · dresden-elektronik/deconz-rest-plugin Wiki · GitHub ) but nothing fixed the issue. No connection to any device could be established.
I tried a fresh installation of Raspberry OS and deconz and used the gateway backup but that did not help either. I reseted a lamp and tried to reconnect it but i had no success in doing so.
Also using a backup image of the whole system from when I new it was working had not positive effect.
So I thought that possibly the stick was broken and I ordered a new one. With the new Stick and restored zigbee configuration it worked again for about 5 Minutes. After I tried to reconnect the lamp that I had previously reset, the connection to all devices failed again and now I’m back at the same point.
Has anyone an idea on what i can do next or what the problem might be? The setup worked pretty stable perviously.
Can you share some logs? In #deconz you can figure out how.
Of course. This is it:
Log
edit: I just started the logging and in the middle i tried to turn on a light through iobroker.
You have interference issues.
19:27:39:575 0x000D6FFFFE03AFE0 error APSDE-DATA.confirm: 0xE1 on task
Are you using an extension cable?
Yes I do, just 30 cm though. I changed nothing there for quite some time and had no problems at all. I will see if I can find a longer USB cable here.
I found a 2m cable. That fixed it. Thanks a lot!
I have no idea what is suddenly causing the interference, however. The setup has been untouched for some time.
Hi all,
I’m the a similar situation. I’m using deconz-docker container 2.18 on a Synology. The stick is connected with a 1m usb extension cable. It has been working like a charm for years and has stopped few weeks ago.
On the logs I can see several messages like this:
This makes me think of an interference problem but I do not know how to work it out.
I bout a 3m extension cable but it doesnt seems to solve the issue.
Any clue?
