MS-105Z (TS0601__TZE200_la2c2uo9)
Using Home Assistant with DeConz (or Zigbee2Mqtt, or ZHA) : pairing works, reports well On/Off status via ConBee OK, but doesn’t respond to commands sent from Home Assistant. Look like integration is broken.
(with a flashed CC2530 / CC2531, MS-105Z works okay, both ways).
I have one too. It work without problem, but as all tuya device, you probably need 2 inclusions
Look at the json as “type”, I thing you have “smart plug”, and you need to have “dimmable light”. Can be repared at restart too.
PS: this working mode is for use with deconz, not the same working mode for Z2M or ZHA.
I’m new to deCONZ. Actually I would have liked it better to work with ZHA – again MS-105Z not responding to commands with ConBee, but working okay with CS2530/CC2531.
I’m trying to change the type to “Dimmable light” with Postman, but it looks like I don’t have the permissions.
The json as it is now:
“etag”: “475006c5a159c39ed1a6731f694da2d2”,
“hascolor”: false,
“lastannounced”: null,
“lastseen”: “2021-12-06T11:41Z”,
“manufacturername”: “Unknown”,
“modelid”: null,
“name”: “Smart plug 3”,
“state”: {
“alert”: “none”,
“on”: true,
“reachable”: true
“swversion”: null,
“type”: “Smart plug”,
“uniqueid”: “cc:86:ec:ff:fe:0f:a4:77-01”
According to post deconz-rest-plugin/issues/5152, I should have these parts as:
“manufacturername”: “_TZE200_la2c2uo9”,
“modelid”: “TS0601”,
Here is the screenshot of what I’m trying to achieve with Postman.
I deleted the device and did again a pairing – I guess this is what you call inclusion. And then I did another pairing. That helped a bit because I now have the model and manufacturer.
“etag”: “090418e173b11072c09cf398bd8bc979”,
“hascolor”: false,
“lastannounced”: “2021-12-07T08:33:59Z”,
“lastseen”: “2021-12-07T08:33Z”,
“name”: “Smart plug 4”,
“state”: {
“alert”: “none”,
“on”: true,
“reachable”: true
“swversion”: null,
But the type remains to smart plug.
No you can’t update yourself the type, but deconz is able to update it (at least is phoscon is still in permit join, “add new light”)
Try to select the node in deconz and press the key L, the device will make a leave/rejoin and I think the usefull code part will be trigered again to update it.
I do a permit join in phoscon
Go to deconz (again, this is part of the HA addon)
Go to the cluster info of my device (smart plug 4) and put the cursor on “Basic Device Setting”
Put my device in pairing mode
Click on the read button
You can skip the part “Put my device in pairing mode”, if the device is already in the network (visible on deconz)
And have you tried with making 2 inclusions, without deleting the device ?
Yes, I actually made several inclusions… With no result. And doing a Leave / Join in the deconz app is not giving any result. It’s still seen as a Fairy Light and not a Dimmable Light.
I’m at loss, what you do suggest to debug / fix the problem further? knowing that integration with a flashed CC2530 / CC2531 works perfectly – the problem is obviously with the Conbee firmware…
Do you have access to the deCONZ GUI via VNC in HA.
Here a screenshot of the device endpoints would be interesting (by clicking on the second circle on the right side of the node).
I would have assumed that as a Smart Plug this device should be working generically, but with Tuya you never know.
Info: The next stable version deCONZ update available in HA is scheduled around mid December, here DDF capabilities are included to make easier changes for this type of devices.
