tc424
July 20, 2022, 3:55pm
1
opened 03:48PM - 20 Jul 22 UTC
This one may not be possible, as the manufacturer & model ID are not populated, … but there is an identifier in the "Date Code" attribute in the first "Basic" cluster that could be used (I appreciate this probably requires a device specific hack, which may be undesirable.) The actual probe temperature seems to be read just fine, it appears in the first temperature cluster (under "01".) The humidity measures just seem to return 0. The second temperature cluster (under "08") doesn't appear to return sensible data.
If this is too much of a disaster zone then feel free to close :)
!!!!! READ THIS FIRST: https://forum.phoscon.de/t/read-me-device-request-read-me/23/2 !!!!!!
## Device
- Product name: MOCREO Temperature Sensor - ST4
- Manufacturer: MOCREO (not shown in basic cluster)
- Model identifier: ST-4 (not shown in basic cluster)
- Sensor
https://www.amazon.co.uk/MOCREO-Temperature-Waterproof-Thermometer-Refrigerator/dp/B09G9MG19D
## Screenshots
Required screenshots:
- Node Info panel
### Basic
### Temperature measurement
This one is a bit of disaster zone as it doesn’t seem to have populated manufacturer or model ID fields, but there is string in the “date code” attribute that could be used to identify it. I do appreciate the devs might not want to add any more device specific hacks though
