# It's time to fix Aqara battery bug
**URL:** <https://forum.phoscon.de/t/its-time-to-fix-aqara-battery-bug/2368>\
**Category:** General Support\
**Created:** [August 24, 2022, 8:15pm UTC](https://forum.phoscon.de/t/its-time-to-fix-aqara-battery-bug/2368 "2022-08-24T20:15:03Z")\
**Posts on this page:** 1\
**Showing post:** 59
<div class="post-metadata">
**Author:** ![bcutter](https://forum.phoscon.de/user_avatar/forum.phoscon.de/bcutter/32/599_2.png) [@bcutter](https://forum.phoscon.de/u/bcutter)\
**Post date:** [February 4, 2024, 7:52pm UTC](https://forum.phoscon.de/t/its-time-to-fix-aqara-battery-bug/2368/59 "2024-02-04T19:52:49Z")
</div>
Managed to implement it.
Unfortunately, instantly after the new DDF started working, Home Assistant reported that few entities (illuminance and battery) of two sensors became unavailable. I checked and compared them.
These (firmware \*21) are working just fine - no change (so far):
 ![grafik](https://forum.phoscon.de/uploads/default/original/2X/5/5cc1dbc3afc4108bbddd7e3a76cbafa9eaeed25e.png)
But these became unavailable (firmware \*27):
 ![grafik](https://forum.phoscon.de/uploads/default/original/2X/f/fa014238c52958fe46e7579636fa076211657c2d.png)
Update:
1 out of 2 devices (firmware \*27) still with `unavailable` entities, the other one recovered within minutes.
What the…?
1. Any idea?
2. Maybe those devices that would have a battery value of 0 (zero) now will be shown as `unavailable` due to the changed DDF? Or shall they keep the last value they had?
Reading of `0001 Power Configuration` cluster:
 ![grafik](https://forum.phoscon.de/uploads/default/original/2X/8/819a6b8a71e30653d7fd2f58827cee57ce8e0418.jpeg)
And this is the deconz API output:
```auto
  "107": {
      "battery": 100,
      "reachable": false,
      "tholddark": 12000,
      "tholdoffset": 7000
    "etag": " ***REMOVED***",
    "lastannounced": null,
    "lastseen": "2024-02-04T19:30Z",
    "manufacturername": "XIAOMI",
    "modelid": "lumi.sen_ill.mgl01",
    "name": "Lichtsensor ***REMOVED***",
      "dark": false,
      "daylight": false,
      "lastupdated": "2023-12-30T19:15:16.375",
      "lightlevel": 0,
      "lux": 0
    "swversion": "0.0.0_0027",
    "type": "ZHALightLevel",
    "uniqueid": " ***REMOVED***"
That ` "reachable": false,` looks suspicious to me…
Update:
- No it’s not suspicious, same for all light sensors not currently triggered.
- After I triggered a value change for the remaining light sensor, its entities came back online.
Theory: after changing the DDF, the `*27` firmware powered light sensors need some kind of trigger/interaction to push their new values. I think the DDF change made them “reset” somehow. Not into that inner processes of deCONZ, so just assumptions…
⚠⚠⚠ **Latest remaining issue: all values don’t update anymore… meaning that illuminance is stuck on the value prior to the DDF swapping…** ⚠⚠⚠
Why does that stuff need to be that complicated… 👿
@Smanar I tested with several sensors: value `"lux": 18` does not update anymore according to the API. What can I do to resolve this?
> **My DDF looks like this (only the battery part changed, put in in the \`/data/.local/share/dresden-elektronik/deCONZ/devices/\` folder and hit "hot reload" in the deCONZ DDF editor):**
> ```auto
> "schema": "devcap1.schema.json",
> "doc:path": "xiaomi/xiaomi_gzcgq01lm_light_sensor.md",
> "doc:hdr": "Light sensor GZCGQ01LM",
> "manufacturername": ["$MF_XIAOMI", "$MF_LUMI"],
> "modelid": ["lumi.sen_ill.mgl01", "lumi.sen_ill.mgl01"],
> "vendor": "Xiaomi",
> "product": "Mijia Light Sensor GZCGQ01LM",
> "status": "Gold",
> "md:known_issues": [],
> "sleeper": true,
> "subdevices": [
> "type": "$TYPE_LIGHT_LEVEL_SENSOR",
> "restapi": "/sensors",
> "uuid": [
> "$address.ext",
> "0x01",
> "0x0400"
> "fingerprint": {
> "profile": "0x0104",
> "device": "0x0106",
> "endpoint": "0x01",
> "in": [
> "0x0001",
> "0x0400"
> "items": [
> "name": "attr/lastseen"
> "name": "attr/manufacturername"
> "name": "attr/modelid",
> "awake": true
> "name": "attr/name"
> "name": "attr/swversion",
> "awake": true,
> "parse": {
> "at": "0x00f7",
> "ep": 1,
> "fn": "xiaomi:special",
> "idx": "0x08",
> "script": "xiaomi_swversion.js"
> "read": {
> "fn": "none"
> "name": "attr/type"
> "name": "attr/uniqueid"
> "name": "config/on"
> "name": "config/battery",
> "awake": true,
> "parse": {
> "at": "0x00f7",
> "ep": 1,
> "idx": "0x01",
> "eval": "const vmin = 2700; const vmax = 3000; const v = Math.max(vmin, Math.min(Attr.val, vmax)); const bat = Math.round(((v - vmin) / (vmax - vmin)) * 100); if (bat>0){Item.val = Math.max(0, Math.min(bat, 100));}"
> "name": "config/reachable"
> "name": "config/tholddark"
> "name": "config/tholdoffset"
> "name": "state/lightlevel",
> "parse": {
> "at": "0x0000",
> "cl": "0x0400",
> "ep": 1,
> "script": "../generic/illuminance_cluster/sml_light_level.js"
> "name": "state/dark"
> "name": "state/daylight"
> "name": "state/lux"
> "name": "state/lastupdated"
> "example": {
> "config": {
> "battery": 100,
> "on": true,
> "reachable": true,
> "tholddark": 12000,
> "tholdoffset": 7000
> "ep": 1,
> "etag": "761fff5a33ee73a8b9e4ec2e8ee5dac2",
> "lastseen": "2021-01-13T12:07Z",
> "name": "Light Sensor",
> "state": {
> "dark": false,
> "daylight": false,
> "lastupdated": "2021-01-13T12:07:27.511",
> "lightlevel": 13425,
> "lux": 22
> "uniqueid": "04:cf:8c:df:3c:7f:1f:80-01-0400"
> "bindings": [
> "bind": "unicast",
> "src.ep": 1,
> "cl": "0x0400",
> "report": [
> "at": "0x0000",
> "dt": "0x21",
> "min": 10,
> "max": 3600,
> "change": "0x0064"
I think it might be because of the changed location…
- HA deCONZ addon default DDF storage: `/usr/share/deCONZ/devices/xiaomi/`
- HA deCONZ addon custom user DDF storage: `/data/.local/share/dresden-elektronik/deCONZ/devices/`
And I think the path to the light level script…
```auto
            "at": "0x0000",
            "cl": "0x0400",
as well as the swversion script…
```auto
          "awake": true,
            "at": "0x00f7",
            "idx": "0x08",
can not be found anymore now.
So:
a) source them in, too?
b) change paths? relative would be difficult, not sure if absolute ones would work?
Another update: fixed now. I copied all the (only two) referenced `*.js` files also to the persistent custom DDF storage (`/data/.local/share/dresden-elektronik/deCONZ/devices/` for HA deCONZ addon/container). Some inconsistent fiddling around with “Edit DDF”, edit another one, open the custom one again etc. together with several “Hot reload” magic in between… finally made it work.
**Values report back via API and are shipped to Home Assistant. ✅**
_That’s when just a small workaround either makes your smart home stop working or takes two hours of your time. Always fun to work with deCONZ, DDFs and stuff._
Note: absolute paths did **NOT work** (even the addon should be able to find the files… really strange). Maybe the DDFs only work with relative paths (as used in the default)? **Would be really interesting to know!**
_[View the full topic](https://forum.phoscon.de/t/its-time-to-fix-aqara-battery-bug/2368)._
