It's time to fix Aqara battery bug
IDK, he is right, on my side I never had 0 value for battery, so using a filter for them is an idea to test.
It’s only I have no idea what the content of the DDF should be to suppress/ignore the 0 % value only for the battery values for the „lumi.sen_ill.mgl01“ device
Can try this DDF, based on deconz-rest-plugin/devices/xiaomi/xiaomi_gzcgq01lm_light_sensor.json at master · dresden-elektronik/deconz-rest-plugin · GitHub
  "doc:path": "xiaomi/xiaomi_gzcgq01lm_light_sensor.md",
  "doc:hdr": "Light sensor GZCGQ01LM",
  "manufacturername": ["$MF_XIAOMI", "$MF_LUMI"],
  "modelid": ["lumi.sen_ill.mgl01", "lumi.sen_ill.mgl01"],
  "vendor": "Xiaomi",
  "product": "Mijia Light Sensor GZCGQ01LM",
  "status": "Gold",
  "md:known_issues": [ ],
  "sleeper": true,
  "subdevices": [
      "type": "$TYPE_LIGHT_LEVEL_SENSOR",
      "restapi": "/sensors",
      "uuid": [
        "$address.ext",
        "0x01",
        "0x0400"
      "fingerprint": {
        "profile": "0x0104",
        "device": "0x0106",
        "endpoint": "0x01",
        "in": [
          "0x0001",
          "0x0400"
          "name": "attr/modelid",
          "awake": true
          "name": "attr/name"
          "name": "attr/swversion",
          "awake": true,
            "at": "0x00f7",
            "fn": "xiaomi:special",
            "idx": "0x08",
            "script": "xiaomi_swversion.js"
          "read": {
            "fn": "none"
          "name": "config/on"
          "name": "config/battery",
          "awake": true,
            "at": "0x00f7",
            "idx": "0x01",
            "eval": "const vmin = 2700; const vmax = 3000; const v = Math.max(vmin, Math.min(Attr.val, vmax)); const bat = Math.round(((v - vmin) / (vmax - vmin)) * 100); if (bat>0){Item.val = Math.max(0, Math.min(bat, 100));}"
          "name": "config/reachable"
          "name": "config/tholddark"
          "name": "config/tholdoffset"
          "name": "state/lightlevel",
            "at": "0x0000",
            "cl": "0x0400",
            "script": "../generic/illuminance_cluster/sml_light_level.js"
          "name": "state/dark"
          "name": "state/daylight"
          "name": "state/lux"
          "name": "state/lastupdated"
      "example": {
          "battery": 100,
          "reachable": true,
          "tholddark": 12000,
          "tholdoffset": 7000
        "etag": "761fff5a33ee73a8b9e4ec2e8ee5dac2",
        "lastseen": "2021-01-13T12:07Z",
        "manufacturername": "XIAOMI",
        "modelid": "lumi.sen_ill.mgl01",
        "name": "Light Sensor",
          "dark": false,
          "daylight": false,
          "lastupdated": "2021-01-13T12:07:27.511",
          "lightlevel": 13425,
          "lux": 22
        "swversion": "0.0.0_0027",
        "type": "ZHALightLevel",
        "uniqueid": "04:cf:8c:df:3c:7f:1f:80-01-0400"
  "bindings": [
      "cl": "0x0400",
          "at": "0x0000",
          "dt": "0x21",
          "min": 10,
          "max": 3600,
          "change": "0x0064"
The magic is here
          "awake": true,
            "at": "0x00f7",
            "idx": "0x01",
