How to add/edit a DDF on Home assistant using text editor?
When I’m trying to install Nano:
bash: apk: command not found
root@core-deconz:~# apt install nano
Reading package lists… Done
Building dependency tree
Reading state information… Done
E: Unable to locate package nano
root@core-deconz:~#
I can see the json file, but don’t know how to modify…
Hello
I’m trying to access over SSH plugin or even with Putty and I can’t execute the first command:
  1. docker container ls
Can you please let me know what I have to do in order to solve this ?
Thank you
Hello, perhaps Hassos docker command not found - Configuration - Home Assistant Community
But there is this comment
This section is not for end users. End users should use the SSH add-on to SSH into Home Assistant
Same result if you use the SSH addon ?
Hello
Yes same result, as you can check in the second Image that I shared in the last post, I’m using the SSH Addon over the Home Assistant
Thank you
And that Execute in Home Assistant Container Context - #5 by doubledutch - Home Assistant OS - Home Assistant Community ?
Else can try the procedure with playing with USB key described on the official link
