How to add/edit a DDF on Home assistant using text editor?
Assumptions confirmed after doing a HA deCONZ addon restart:
  1. Original file (/usr/share/deCONZ/devices/blitzwolf/bw_shp13_smart_plug.json) is overwritten/reset to default :white_check_mark:
  2. Custom file (/data/.local/share/dresden-elektronik/deCONZ/devices/bw_shp13_smart_plug_MyCustomConfig.json) still exists and is untouched (timestamp unchanged) :white_check_mark:
Additional confirmation:
  1. Selecting “Edit DDF” in deCONZ VNC GUI (right click) opens my custom config DDF file. :white_check_mark:
  2. Changes applied in custom config are (still/again) active (update interval is roughly 1 minute instead of default 5 to 8 minutes) :white_check_mark:
Therefore I’m fine for the moment, will test/check if all this behaves the same when updating the deCONZ addon.
Another final information regarding the initial question (how to edit a DDF on Home Assistant):
  1. Login via SSH to HA
  2. Login deCONZ docker container: docker exec -it addon_core_deconz bash
  3. Install a text editor e. g. nano for editing files on the CLI: apt update; apt install nano (note: this will be undone once the container is restarted or updated)
  4. Edit your DDF file with e. g. nano /usr/share/deCONZ/devices/blitzwolf/bw_shp13_smart_plug.json
  5. Don’t forget to “hot reload” the DDF changes using deCONZ (VNC GUI)
See also Permanent changes in deCONZ addon/container (survive restart / update) - Home Assistant OS - Home Assistant Community with a lot of additional/detailed information.
