There is a zigbee request “Leave” that can be used for light device Lights - deCONZ REST-API
But I almost sure it don’t work at 100% and I m sure it don’t work for sensor.
Generaly to remove a sensor from a network, we re-include it on a new one. Can just make a reset procedure, but don’t open the deconz deconz (don’t clic on “add new sensor”).
I know you don’t need group, but this device need a group to send it’s broadcast request to it, to don’t perturb the whole network.
For the procedure I don’t know the better way, and it will be not easy as the device is sleeping, so you will need to wake it for every tests.
what I would do on my side
- use the DDF with group feature
- include the device
- wait for all configuration was done, can take time on sleeping device
- check on the “group cluster” if there is a group configured for this device
- if not create one, and make all bind to this group.
But it’s possible as there is some group feature on this DDF the DDF core will try to overwrite thoses setting, so if it don’t work, new try with the first DDF without group feature.
