I’m clearly not familiar with alarm management in Zigbee environment. I used DDF proposed by @Swoop related to issue https://forum.phoscon.de/t/heiman-warningdevice-ef-3-0-siren-no-battery-and-tampered-status/2346 opened by @monpelaud. I just added ZHABattery as a suggestion because the specific cluster 0001 has attributes for that purpose.
Well, correcting it in DDF lead me to another issue. config/battery is set to 0 where state/battery was with a right value
"battery": 0,
"pending": [],
"reachable": true
"etag": "090140dfffed16e5e1129a711c762381",
"lastannounced": null,
"lastseen": "2022-10-07T17:07Z",
"manufacturername": "HEIMAN",
"modelid": "WarningDevice-EF-3.0",
"name": "Sirene bureau alarme",
"alarm": null,
"lastupdated": "2022-10-06T21:35:13.264",
"lowbattery": null
"type": "ZHAAlarm",
"uniqueid": "84:71:27:ff:fe:fe:ab:08-01-0500",
"id": "36",
"deviceclass": "sensors"
"battery": 0,
"pending": [],
"reachable": true
"etag": "3f0218f94f714dae82c54182ee0143f8",
"lastseen": "2022-10-07T17:13Z",
"alarm": null,
"battery": 87,
"lastupdated": "2022-10-07T17:13:21.354",
"lowbattery": null
"type": "ZHAAlarm",
"id": "36",
Try with removing state/battery and using
"name": "config/battery",
"refresh.interval": 3600,
"at": "0x0021",
"cl": "0x0001",
"eval": "Item.val = Attr.val / 2",
"fn": "zcl"
To force it.
I don’t understand why should I configure the read-only attribute for this device to config/battery as the state/battery also exists and works ?
State/battery is reserved to the sensor ZHABattery.
Light device don’t have “config” but don’t have battery, so we use the ZHABattery for battery covering for exemple.
And sensor use config/battery, never state/battery.
That’s what I initialy did that did not work.
But after changing config/battery by state/battery in the DDF make the item apearing with a value (87 in my example above).
Here is the DDF :
"manufacturername": [
"Heiman",
"HEIMAN"
"modelid": [
"WarningDevice",
"vendor": "Heiman",
"product": "Smart siren HS2WD-E",
"sleeper": false,
"status": "Silver",
"path": "/devices/HS2WD-E.json",
"type": "$TYPE_WARNING_DEVICE",
"restapi": "/lights",
"0x01"
"name": "attr/swversion"
"name": "state/alert",
"default": "none"
"name": "state/reachable"
"type": "ZHAAlarm",
"restapi": "/sensors",
"0x01",
"0x0500"
"fingerprint": {
"profile": "0x0104",
"device": "0x0403",
"endpoint": "0x01",
"in": [
"0x0000",
"0x0001",
"0x0500"
"at": "0x0021",
"cl": "0x0001",
"fn": "zcl"
"default": 0
"name": "config/enrolled",
"public": false
"name": "config/on"
"name": "config/pending"
"name": "config/reachable"
"name": "state/alarm"
"name": "state/lastupdated"
"name": "state/lowbattery"
"bindings": [
"cl": "0x0001",
"at": "0x0021",
"dt": "0x20",
"min": 120,
"max": 3600,
"change": "0x00000001"
"dst.ep": 1,
"cl": "0x0500"
"cl": "0x0502",
"at": "0x0000",
"dt": "0x21",
"min": 30,
"max": 120
and the resulting json :
"battery": 0,
"pending": [],
"reachable": true
"etag": "712a292a7d2d5d82abd71445319ed49c",
"lastseen": "2022-10-11T16:23Z",
"alarm": null,
"lastupdated": "2022-10-11T14:46:02.369",
"lowbattery": null
"type": "ZHAAlarm",
"id": "36",
That’s a bit weird because in the log I got the retreiving of the data :
12:42:02:934 50:0b:91:40:00:02:ca:1c-01-0201/config/heatsetpoint expression: Item.val = Attr.val; --> 1800
**12:42:03:434 84:71:27:ff:fe:fe:ab:08-01-0500/config/battery expression: Item.val = Attr.val / 2 --> 86.5**
12:42:04:069 50:0b:91:40:00:02:ca:1c-01-0201/config/heatsetpoint expression: Item.val = Attr.val; --> 1800
**12:42:05:779 84:71:27:ff:fe:fe:ab:08-01-0500/config/battery expression: Item.val = Attr.val / 2 --> 86.5**
Seriously, every day a new problem …
What is your deconz version ?
Just for the fun, can you try using “/ 3” in the DDF instead of using " / 2" to check if the DDF is realy used.
Or removing the “defaut” : 0
No line that set the “0” value just after in logs ?
I guess there is no trouble with the “defaut” : 0 because the value has been updated when the percentage rise from 86.5 to 87.
Tried to put the calculation with /3 instead of /2 and the DDF is used
15:48:40:752 84:71:27:ff:fe:fe:ab:08-01-0500/config/battery expression: Item.val = Attr.val / 3 --> 57.666666666666664
But no value transmitted in the json … it keeps 87
"battery": 87,
"pending": [],
"reachable": true
"etag": "98b96a8001ec29fd4d389cea0791f31e",
"lastseen": "2022-10-11T19:23Z",
"alarm": null,
"lowbattery": null
"type": "ZHAAlarm",
"id": "36",
Could it be a rounded issue ? Should this value be an integer to be used ?
I will link this post to dev channel to have tips.
Seriously I have no idea what happen
Can you show the complete DDF ?
Of course, here it is
"Heiman",
"HEIMAN"
"modelid": [
"WarningDevice",
"vendor": "Heiman",
"sleeper": false,
"status": "Silver",
"0x01"
"default": "none"
"type": "ZHAAlarm",
"0x01",
"0x0500"
"fingerprint": {
"device": "0x0403",
"endpoint": "0x01",
"in": [
"0x0000",
"0x0001",
"0x0500"
"refresh.interval": 120,
"read": {
"at": "0x0021",
"cl": "0x0001",
"fn": "zcl"
"at": "0x0021",
"cl": "0x0001",
"fn": "zcl"
"default": 0
"public": false
"name": "config/on"
"bindings": [
"cl": "0x0001",
"at": "0x0021",
"dt": "0x20",
"min": 120,
"max": 3600,
"dst.ep": 1,
"cl": "0x0500"
"cl": "0x0502",
"at": "0x0000",
"dt": "0x21",
"min": 30,
"max": 120
Tried to replace the calculated value by Item.val = Math.round(Attr.val / 3); in the DDF and it works instantaneously !
"battery": 58,
"pending": [],
"reachable": true
"etag": "bb0d59a153d90eb768d91286dfc176c9",
"lastseen": "2022-10-12T16:46Z",
"alarm": null,
"lowbattery": null
"type": "ZHAAlarm",
Then really think that a integer is attended here.
Then replaced it by Item.val = Math.round(Attr.val / 2); for the moment.
And BTW Swoops have see another strange problem, look at your device json, you have an entry “deviceclass”
"id": "36",
It may be came from the DDF that @Swoop gave in the other thread : https://forum.phoscon.de/t/heiman-warningdevice-ef-3-0-siren-no-battery-and-tampered-status/2346/5
“type”: “ZHAAlarm”,
“restapi”: “/sensors”,
“uuid”: [
“$address.ext”,
“0x01”,
“0x0500
And it’s the same in PR #6397
