FLS-M Integration Issues to Aqara M3 via Matter :-(
Hi all,
After seeing that the FLS-M integrates with Aqara via Matter, I went all in and purchased 4x FLS-M’s as I have a full Aqara lighting / switching system in my house.
I then purchased addressable LED strips (WS2814 / WRGB), 4x suitable 24V power supplies, connected everything as required, upgraded the firmware on the FLS-M’s, set the DIP’s all to On and connected the first FLS-M to the laptop to use Config Builder.
I’ve tried many different config combo’s to get it working fully correctly without success, so will provide some examples of the setup and the issue caused…
Scenario 1
0.98m addressable LED strip with 0.07m segments, therefore Total Segments = 14.
Controllable Light 1…
  • Layer 1
  • Start 1
  • End 14
    => Result all works well
Scenario 2
  • Layer 1
    - Start 1
    - End 1
    Controllable Light 2…
  • Layer 1
    - Start 2
    - End 2
    Controllable Light 3…
  • Layer 1
    - Start 3
    - End 3
    => Results are that switching on Controllable Light 3 turns on Segment 3 correctly.
    Switching on Controllable Light 2 turns on Segment 2 correctly.
    Switching on Controllable Light 1 turns on ALL Segments incorrectly :frowning:
Scenario 3
  • Layer 1
    - Start 1
    - End 2
  • Layer 1
    - Start 3
    - End 4
    => Results are that switching on Controllable Light 2 turns on Segment 3-4 correctly.
    Switching on Controllable Light 1 turns on Segment 1-2 correctly (this didn’t switch on all segments with 1 and 2 selected).
Scenario 4
  • Layer 1
    - Start 1
    - End 7
  • Layer 1
    - Start 8
    - End 14
    => Results are that switching on either Controllable Light works. However, in the Aqara app, selecting the color of Controllable Light 2 changes the color of Controllable Light 1 only. In the Aqara app changing the color for any Controllable Light apart from Controllable Light 1 does not change the color for Controllable Light X.
I can expose the FLS-M to Home Assistant using the Aqara M3 as a Matter Bridge. When using HA, I can correctly set the colors for individual Controllable Light and they set on the LED strip (via the FLS-M) correctly.
For me, this sounds like an Aqara issue and I have also reported this to Aqara, but wondered if anyone from Phoscon has experienced this with the product being stated as working with Aqara?
Thanks
