# BW-SHP13 - Consumption Values not available
**URL:** <https://forum.phoscon.de/t/bw-shp13-consumption-values-not-available/1741>\
**Category:** General Support\
**Created:** [March 15, 2022, 7:34pm UTC](https://forum.phoscon.de/t/bw-shp13-consumption-values-not-available/1741 "2022-03-15T19:34:30Z")\
**Posts on this page:** 1\
**Showing post:** 9
<div class="post-metadata">
**Author:** ![Smanar](https://forum.phoscon.de/user_avatar/forum.phoscon.de/smanar/32/60_2.png) [@Smanar](https://forum.phoscon.de/u/Smanar)\
**Post date:** [May 9, 2022, 2:36pm UTC](https://forum.phoscon.de/t/bw-shp13-consumption-values-not-available/1741/9 "2022-05-09T14:36:02Z")
</div>
Just use a text editor. if all is normal you already have a bw\_shp13\_smart\_plug.json in the “devices” folder.
If you have HA or other docker OS [How to add/edit a DDF on Home assistant using text editor? - #2 by Smanar](https://forum.phoscon.de/t/how-to-add-edit-a-ddf-on-home-assistant-using-text-editor/1839/2)
For normal OS
> All DDF provided directly with deCONZ typically reside in `/usr/share/deCONZ/devices/` on a Linux system and are loaded first. However, files residing in the home directory of the user running deCONZ (e.g. `/home/<DECONZUSER>/.local/share/dresden-elektronik/deCONZ/devices`) will override the pre-packaged files to allow users to amend and keep their own files if desired.
_[View the full topic](https://forum.phoscon.de/t/bw-shp13-consumption-values-not-available/1741)._
