Here a log:
g-error=2 | tee debug.txt
15:43:19:671 HTTP Server listen on address 0.0.0.0, port: 80, root: /usr/share/d eCONZ/webapp/
15:43:19:694 /home/USER/.local/share/dresden-elektronik/deCONZ/config.ini exist s and is writeable
15:43:19:694 /home/USER/.local/share/dresden-elektronik/deCONZ/zll.db exists an d is writeable
15:43:19:825 COM: /dev/ttyACM0 : ConBee II (0x1CF1/0x0030)
15:43:19:826 COM: /dev/ttyAMA0 : (0x0000/0x0000)
15:43:19:826 COM: /dev/ttyS0 : (0x0000/0x0000)
15:43:19:826 dev /dev/ttyS0 (/dev/ttyS0)
15:43:19:827 ZCLDB init file /home/USER/.local/share/dresden-elektronik/deCONZ/ zcldb.txt
15:43:19:997 DDF enabled for Gold status
15:43:20:173 parent process -bash
15:43:20:173 gw run mode: normal
15:43:20:173 GW sd-card image version file does not exist: /home/USER/.local/sh are/dresden-elektronik/deCONZ/gw-version
15:43:20:174 sd-card cid: 035344534331364780ffffffff014100
15:43:20:175 DB sqlite version 3.34.1
15:43:20:176 DB PRAGMA page_count: 57
15:43:20:176 DB PRAGMA page_size: 4096
15:43:20:176 DB PRAGMA freelist_count: 1
15:43:20:176 DB file size 233472 bytes, free pages 1
15:43:20:176 DB PRAGMA user_version: 9
15:43:20:176 DB cleanup
15:43:20:177 DB create temporary views
15:43:20:178 DB view [0] created
15:43:20:178 DB view [1] created
15:43:20:179 DB view [2] created
15:43:20:179 DB view [3] created
15:43:20:179 sql exec SELECT apikey,devicetype,createdate,lastusedate,useragent FROM auth
15:43:20:185 sql exec SELECT key FROM config2
15:43:20:185 sql exec SELECT key,value FROM config2
15:43:20:185 Load config UTC: 2022-11-21T12:15:32 from db.
15:43:20:185 Load config announceinterval: 45 from db.
15:43:20:185 Load config announceurl: https://phoscon.de/discover from db.
15:43:20:185 Load config apiversion: 2.19.01 from db.
15:43:20:185 Load config bridgeid: 00212EFFFF054FD3 from db.
15:43:20:185 Load config datastoreversion: 93 from db.
15:43:20:185 Load config dhcp: true from db.
15:43:20:185 Load config discovery: true from db.
15:43:20:185 Load config factorynew: false from db.
15:43:20:185 Load config fwneedupdate: false from db.
15:43:20:185 Load config fwupdatestate: idle from db.
15:43:20:186 Load config fwversion: 0x26720700 from db.
15:43:20:186 Load config gateway: 127.0.0.1 from db.
15:43:20:186 Load config group0: 65520 from db.
15:43:20:186 Load config groupdelay: 50 from db.
15:43:20:186 Load config gwpassword: $1$8282jdkm$yHoDC0NkogvF28IvJrtnA/ from db.
15:43:20:186 Load config gwusername: delight from db.
15:43:20:186 Load config homebridge: not-managed from db.
15:43:20:186 Load config homebridge-pin: from db.
15:43:20:186 Load config homebridgepin: from db.
15:43:20:186 Load config homebridgeupdate: false from db.
15:43:20:186 Load config homebridgeupdateversion: from db.
15:43:20:186 Load config homebridgeversion: from db.
15:43:20:186 Load config ipaddress: 192.168.2.3 from db.
15:43:20:186 Load config linkbutton: false from db.
15:43:20:186 Load config localtime: 2022-11-21T13:15:32 from db.
15:43:20:186 Load config mac: 38:60:77:7c:53:18 from db.
15:43:20:186 Load config modelid: deCONZ from db.
15:43:20:186 Load config name: ZigBee from db.
15:43:20:186 Load config netmask: 255.0.0.0 from db.
15:43:20:186 Load config networkopenduration: 180 from db.
15:43:20:186 Load config otauactive: false from db.
15:43:20:186 Load config otaustate: off from db.
15:43:20:186 Load config panid: 0 from db.
15:43:20:186 Load config permitjoin: 0 from db.
15:43:20:186 Load config permitjoinfull: 0 from db.
15:43:20:186 Load config port: 80 from db.
15:43:20:186 Load config portalservices: false from db.
15:43:20:186 Load config proxyaddress: none from db.
15:43:20:186 Load config proxyport: 0 from db.
15:43:20:186 Load config rfconnect: 1 from db.
15:43:20:186 Load config rfconnected: false from db.
15:43:20:186 Load config rgbwdisplay: 1 from db.
15:43:20:186 Load config runmode: systemd/headless from db.
15:43:20:186 Load config starterkitid: from db.
15:43:20:186 Load config swcommit: ac888e70b2968d7fa80a8c66e35ac06e4dd5c5e1 from db.
15:43:20:186 Load config swupdatestate: noupdates from db.
15:43:20:186 Load config swversion: 2.19.01 from db.
15:43:20:186 Load config system: linux-gw from db.
15:43:20:186 Load config timeformat: 24h from db.
15:43:20:186 Load config timezone: Europe/Berlin from db.
15:43:20:186 Load config updatechannel: stable from db.
15:43:20:186 Load config uuid: 28c3b1ca-f069-4ab3-b5ea-01f5b5e5c8e8 from db.
15:43:20:186 Load config websocketnotifyall: true from db.
15:43:20:186 Load config websocketport: 443 from db.
15:43:20:186 Load config wifi: not-configured from db.
15:43:20:186 Load config wifibackupname: from db.
15:43:20:186 Load config wifibackuppw: from db.
15:43:20:186 Load config wifibackuppwenc: from db.
15:43:20:186 Load config wifichannel: 1 from db.
15:43:20:186 Load config wificlientname: from db.
15:43:20:186 Load config wificlientpw: from db.
15:43:20:186 Load config wifiip: 192.168.8.1 from db.
15:43:20:186 Load config wifilastupdated: 0 from db.
15:43:20:186 Load config wifimgmt: 0 from db.
15:43:20:186 Load config wifiname: from db.
15:43:20:186 Load config wifipageactive: false from db.
15:43:20:186 Load config wifipw: from db.
15:43:20:186 Load config wifipwenc: from db.
15:43:20:186 Load config wifitype: accesspoint from db.
15:43:20:186 Load config workingname: from db.
15:43:20:186 Load config workingpw: from db.
15:43:20:186 Load config workingpwenc: from db.
15:43:20:186 Load config workingtype: from db.
15:43:20:186 Load config zclvaluemaxage: 0 from db.
15:43:20:186 Load config zigbeechannel: 11 from db.
15:43:20:187 Load config disablePermitJoinAutoOff: false from db.
15:43:20:187 Load config lightlastseeninterval: 60 from db.
15:43:20:187 sql exec SELECT key,value FROM userparameter
15:43:20:187 sql exec SELECT * FROM groups
15:43:20:187 Sqlite group: gid = 0xFFF0
15:43:20:187 Sqlite group: name = All
15:43:20:187 Sqlite group: state = normal
15:43:20:187 Sqlite group: hidden = false
15:43:20:187 Sqlite group: type = LightGroup
15:43:20:187 Sqlite group: class = Other
15:43:20:187 DB found group All 0xFFF0
15:43:20:188 Sqlite group: gid = 0x0001
15:43:20:188 Sqlite group: name = TRADFRI on/off switch
15:43:20:188 Sqlite group: state = normal
15:43:20:188 Sqlite group: devicemembership = 25
15:43:20:188 Sqlite group: hidden = false
15:43:20:188 Sqlite group: type = LightGroup
15:43:20:188 Sqlite group: class = Other
15:43:20:188 Sqlite group: uniqueid = 94:34:69:ff:fe:5d:09:49
15:43:20:188 DB found group TRADFRI on/off switch 0x0001
15:43:20:188 Sqlite group: gid = 0x0002
15:43:20:188 Sqlite group: name = Wohnzimmer Deckenleuchten
15:43:20:188 Sqlite group: state = deleted
15:43:20:188 DB found group Wohnzimmer Deckenleuchten 0x0002
15:43:20:188 Sqlite group: gid = 0x0003
15:43:20:188 DB found group Wohnzimmer Deckenleuchten 0x0003
15:43:20:189 Sqlite group: gid = 0x0004
15:43:20:189 Sqlite group: name = TRADFRI motion sensor
15:43:20:189 Sqlite group: state = normal
15:43:20:189 Sqlite group: devicemembership = 15
15:43:20:189 Sqlite group: hidden = false
15:43:20:189 Sqlite group: type = LightGroup
15:43:20:189 Sqlite group: class = Other
15:43:20:189 Sqlite group: uniqueid = 8c:f6:81:ff:fe:06:52:d3
15:43:20:189 DB found group TRADFRI motion sensor 0x0004
15:43:20:189 Sqlite group: gid = 0x0005
15:43:20:189 Sqlite group: devicemembership = 16
15:43:20:189 Sqlite group: uniqueid = 2c:11:65:ff:fe:03:c2:9f
15:43:20:189 DB found group TRADFRI motion sensor 0x0005
15:43:20:189 Sqlite group: gid = 0x0006
15:43:20:189 Sqlite group: devicemembership = 18
15:43:20:189 DB found group TRADFRI motion sensor 0x0006
15:43:20:189 Sqlite group: gid = 0x0007
15:43:20:190 Sqlite group: name = TRADFRI motion sensor
15:43:20:190 Sqlite group: state = normal
15:43:20:190 Sqlite group: devicemembership = 19
15:43:20:190 Sqlite group: hidden = false
15:43:20:190 Sqlite group: type = LightGroup
15:43:20:190 Sqlite group: class = Other
15:43:20:190 Sqlite group: uniqueid = 2c:11:65:ff:fe:03:c2:9f
15:43:20:190 DB found group TRADFRI motion sensor 0x0007
15:43:20:190 Sqlite group: gid = 0x0008
15:43:20:190 Sqlite group: name = TRADFRI on/off switch
15:43:20:190 Sqlite group: state = deleted
15:43:20:190 Sqlite group: uniqueid = 94:34:69:ff:fe:5d:09:49
15:43:20:190 DB found group TRADFRI on/off switch 0x0008
15:43:20:190 Sqlite group: gid = 0x0009
15:43:20:190 Sqlite group: name = Wohnzimmer Deckenleuchten
15:43:20:190 DB found group Wohnzimmer Deckenleuchten 0x0009
15:43:20:190 Sqlite group: gid = 0x000A
15:43:20:191 Sqlite group: state = normal
15:43:20:191 Sqlite group: devicemembership = 28
15:43:20:191 Sqlite group: hidden = false
15:43:20:191 Sqlite group: type = LightGroup
15:43:20:191 Sqlite group: class = Other
15:43:20:191 Sqlite group: uniqueid = dc:8e:95:ff:fe:c3:71:d2
15:43:20:191 DB found group TRADFRI on/off switch 0x000A
15:43:20:191 Sqlite group: gid = 0x000B
15:43:20:191 Sqlite group: name = TRADFRI motion sensor
15:43:20:191 Sqlite group: devicemembership = 29
15:43:20:191 Sqlite group: uniqueid = 58:8e:81:ff:fe:36:c5:be
15:43:20:191 DB found group TRADFRI motion sensor 0x000B
15:43:20:191 Sqlite group: gid = 0x000C
15:43:20:191 Sqlite group: devicemembership = 30
15:43:20:191 Sqlite group: uniqueid = 58:8e:81:ff:fe:36:c5:d9
15:43:20:191 DB found group TRADFRI motion sensor 0x000C
15:43:20:191 sql exec SELECT * FROM resourcelinks
15:43:20:192 Sqlite schedule: id = 1
15:43:20:192 Sqlite schedule: json = {"classid":3009,"description":"Resourcelink for switch rule","links":["/groups/2","/sensors/94:34:69:ff:fe:5d:09:49-01-1000 ","/rules/1","/rules/2","/sensors/13","/rules/3","/rules/4","/rules/5"],"name":" opt_pushDim","owner":"F895BCFEC1","recycle":false,"type":"Link"}
15:43:20:192 Sqlite schedule: id = 2
15:43:20:192 Sqlite schedule: json = {"classid":3016,"description":"Resourcelink for switch rule","links":["/groups/2","/sensors/94:34:69:ff:fe:5d:09:49-01-1000 ","/sensors/14","/rules/6","/rules/7"],"name":"opt_toggleColorLoop","owner":"F89 5BCFEC1","recycle":false,"type":"Link"}
15:43:20:192 Sqlite schedule: id = 3
15:43:20:192 Sqlite schedule: json = {"classid":3009,"description":"Resourcelink for switch rule","links":["/groups/3","/sensors/94:34:69:ff:fe:5d:09:49-01-1000 ","/rules/8","/rules/9","/sensors/17","/rules/10","/rules/11","/rules/12"],"name ":"opt_pushDim","owner":"7CA421C07A","recycle":false,"type":"Link"}
15:43:20:192 Sqlite schedule: id = 4
15:43:20:192 Sqlite schedule: json = {"classid":3009,"description":"Resourcelink for switch rule","links":["/groups/9","/sensors/94:34:69:ff:fe:5d:09:49-01-1000 ","/rules/13","/rules/14","/sensors/27","/rules/15","/rules/16","/rules/17"],"na me":"opt_pushDim","owner":"FD5BB059AE","recycle":false,"type":"Link"}
15:43:20:192 sql exec SELECT * FROM scenes
15:43:20:192 Sqlite scene: gsid = 0x000901
15:43:20:192 Sqlite scene: gid = 0x0009
15:43:20:192 Sqlite scene: sid = 0x01
15:43:20:192 Sqlite scene: name = TV
15:43:20:192 Sqlite scene: transitiontime = 10
15:43:20:192 Sqlite scene: lights = [{"bri":153,"cm":"none","lid":"2","on":true, "tt":10},{"bri":140,"cm":"none","lid":"3","on":true,"tt":10},{"bri":254,"cm":"no ne","lid":"8","on":true,"tt":10}]
15:43:20:193 DB found scene sid: 0x01, gid: 0x0009
15:43:20:193 Sqlite scene: gsid = 0x000902
15:43:20:193 Sqlite scene: gid = 0x0009
15:43:20:193 Sqlite scene: sid = 0x02
15:43:20:193 Sqlite scene: name = OP
15:43:20:193 Sqlite scene: transitiontime = 10
15:43:20:193 Sqlite scene: lights = [{"bri":153,"cm":"none","lid":"2","on":true, "tt":10},{"bri":140,"cm":"none","lid":"3","on":true,"tt":10},{"bri":254,"cm":"no ne","lid":"8","on":true,"tt":10}]
15:43:20:193 DB found scene sid: 0x02, gid: 0x0009
15:43:20:193 sql exec SELECT * FROM rules
15:43:20:193 Sqlite rules: rid = 1
15:43:20:193 Sqlite rules: name = Rule PUSHDIM_ON
15:43:20:193 Sqlite rules: created = 2022-10-11T20:43:45
15:43:20:193 Sqlite rules: etag = "4447c96fd4191b4114687fcf498908b3"
15:43:20:193 Sqlite rules: lasttriggered = none
15:43:20:193 Sqlite rules: owner = F895BCFEC1
15:43:20:193 Sqlite rules: status = enabled
15:43:20:193 Sqlite rules: timestriggered = 0
15:43:20:193 Sqlite rules: actions = [{"address":"/groups/2/action","body":{"on" :true},"method":"PUT"}]
15:43:20:194 Sqlite rules: conditions = [{"address":"/sensors/94:34:69:ff:fe:5d: 09:49-01-1000/state/buttonevent","operator":"eq","value":1002},{"address":"/sens ors/94:34:69:ff:fe:5d:09:49-01-1000/state/lastupdated","operator":"dx"},{"addres s":"/groups/2/state/any_on","operator":"eq","value":false}]
15:43:20:194 Sqlite rules: periodic = 0
15:43:20:194 DB found rule Rule PUSHDIM_ON 1
15:43:20:194 Sqlite rules: rid = 2
15:43:20:194 Sqlite rules: name = Rule PUSHDIM_OFF
15:43:20:194 Sqlite rules: created = 2022-10-11T20:43:45
15:43:20:194 Sqlite rules: etag = "4447c96fd4191b4114687fcf498908b3"
15:43:20:194 Sqlite rules: lasttriggered = none
15:43:20:194 Sqlite rules: owner = F895BCFEC1
15:43:20:194 Sqlite rules: status = enabled
15:43:20:194 Sqlite rules: timestriggered = 0
15:43:20:194 Sqlite rules: actions = [{"address":"/groups/2/action","body":{"on" :false},"method":"PUT"}]
15:43:20:194 Sqlite rules: conditions = [{"address":"/sensors/94:34:69:ff:fe:5d: 09:49-01-1000/state/buttonevent","operator":"eq","value":1002},{"address":"/sens ors/94:34:69:ff:fe:5d:09:49-01-1000/state/lastupdated","operator":"dx"},{"addres s":"/groups/2/state/any_on","operator":"eq","value":true}]
15:43:20:195 Sqlite rules: periodic = 0
15:43:20:195 DB found rule Rule PUSHDIM_OFF 2
15:43:20:195 Sqlite rules: rid = 3
15:43:20:195 Sqlite rules: name = Rule PUSHDIM_START_UP
15:43:20:195 Sqlite rules: created = 2022-10-11T20:43:45
15:43:20:195 Sqlite rules: etag = "e6f2cd988b042cf9c9c840e11f359b1d"
15:43:20:195 Sqlite rules: lasttriggered = none
15:43:20:195 Sqlite rules: owner = F895BCFEC1
15:43:20:195 Sqlite rules: status = enabled
15:43:20:195 Sqlite rules: timestriggered = 0
15:43:20:195 Sqlite rules: actions = [{"address":"/groups/2/action","body":{"bri _inc":254,"transitiontime":45},"method":"PUT"},{"address":"/sensors/13/state/"," body":{"flag":false},"method":"PUT"}]
15:43:20:195 Sqlite rules: conditions = [{"address":"/sensors/94:34:69:ff:fe:5d: 09:49-01-1000/state/buttonevent","operator":"eq","value":1001},{"address":"/sens ors/94:34:69:ff:fe:5d:09:49-01-1000/state/buttonevent","operator":"dx"},{"addres s":"/sensors/13/state/flag","operator":"eq","value":true}]
15:43:20:195 DB found rule Rule PUSHDIM_START_UP 3
15:43:20:195 Sqlite rules: rid = 4
15:43:20:195 Sqlite rules: name = Rule PUSHDIM_START_DOWN
15:43:20:195 Sqlite rules: actions = [{"address":"/groups/2/action","body":{"bri _inc":-254,"transitiontime":45},"method":"PUT"},{"address":"/sensors/13/state/", "body":{"flag":true},"method":"PUT"}]
15:43:20:195 Sqlite rules: conditions = [{"address":"/sensors/94:34:69:ff:fe:5d: 09:49-01-1000/state/buttonevent","operator":"eq","value":1001},{"address":"/sens ors/94:34:69:ff:fe:5d:09:49-01-1000/state/buttonevent","operator":"dx"},{"addres s":"/sensors/13/state/flag","operator":"eq","value":false}]
15:43:20:195 DB found rule Rule PUSHDIM_START_DOWN 4
15:43:20:196 Sqlite rules: rid = 5
15:43:20:196 Sqlite rules: name = Rule PUSHDIM_STOP
15:43:20:196 Sqlite rules: created = 2022-10-11T20:43:45
15:43:20:196 Sqlite rules: etag = "e6f2cd988b042cf9c9c840e11f359b1d"
15:43:20:196 Sqlite rules: lasttriggered = none
15:43:20:196 Sqlite rules: owner = F895BCFEC1
15:43:20:196 Sqlite rules: status = enabled
15:43:20:196 Sqlite rules: timestriggered = 0
15:43:20:196 Sqlite rules: actions = [{"address":"/groups/2/action","body":{"bri _inc":0},"method":"PUT"}]
15:43:20:196 Sqlite rules: conditions = [{"address":"/sensors/94:34:69:ff:fe:5d: 09:49-01-1000/state/buttonevent","operator":"eq","value":1003},{"address":"/sens ors/94:34:69:ff:fe:5d:09:49-01-1000/state/lastupdated","operator":"dx"}]
15:43:20:196 Sqlite rules: periodic = 0
15:43:20:196 DB found rule Rule PUSHDIM_STOP 5
15:43:20:196 Sqlite rules: rid = 6
15:43:20:196 Sqlite rules: name = Rule TOOGLE_START_COLORLOOP
15:43:20:196 Sqlite rules: created = 2022-10-11T20:46:25
15:43:20:196 Sqlite rules: actions = [{"address":"/groups/2/action","body":{"col orloopspeed":"8","effect":"colorloop","sat":254},"method":"PUT"},{"address":"/se nsors/14/state/","body":{"flag":false},"method":"PUT"}]
15:43:20:196 Sqlite rules: conditions = [{"address":"/sensors/94:34:69:ff:fe:5d: 09:49-01-1000/state/buttonevent","operator":"eq","value":1002},{"address":"/sens ors/94:34:69:ff:fe:5d:09:49-01-1000/state/lastupdated","operator":"dx"},{"addres s":"/sensors/14/state/flag","operator":"eq","value":true}]
15:43:20:196 DB found rule Rule TOOGLE_START_COLORLOOP 6
15:43:20:196 Sqlite rules: rid = 7
15:43:20:196 Sqlite rules: name = Rule TOOGLE_STOP_COLORLOOP
15:43:20:196 Sqlite rules: actions = [{"address":"/groups/2/action","body":{"eff ect":"none"},"method":"PUT"},{"address":"/sensors/14/state/","body":{"flag":true },"method":"PUT"}]
15:43:20:196 Sqlite rules: conditions = [{"address":"/sensors/94:34:69:ff:fe:5d: 09:49-01-1000/state/buttonevent","operator":"eq","value":1002},{"address":"/sens ors/94:34:69:ff:fe:5d:09:49-01-1000/state/lastupdated","operator":"dx"},{"addres s":"/sensors/14/state/flag","operator":"eq","value":false}]
15:43:20:197 Sqlite rules: periodic = 0
15:43:20:197 DB found rule Rule TOOGLE_STOP_COLORLOOP 7
15:43:20:197 Sqlite rules: rid = 8
15:43:20:197 Sqlite rules: name = Rule PUSHDIM_ON
15:43:20:197 Sqlite rules: created = 2022-11-03T21:21:30
15:43:20:197 Sqlite rules: etag = "e6f2cd988b042cf9c9c840e11f359b1d"
15:43:20:197 Sqlite rules: lasttriggered = none
15:43:20:197 Sqlite rules: owner = 7CA421C07A
15:43:20:197 Sqlite rules: status = enabled
15:43:20:197 Sqlite rules: timestriggered = 0
15:43:20:197 Sqlite rules: actions = [{"address":"/groups/3/action","body":{"on" :true},"method":"PUT"}]
15:43:20:197 Sqlite rules: conditions = [{"address":"/sensors/94:34:69:ff:fe:5d: 09:49-01-1000/state/buttonevent","operator":"eq","value":1002},{"address":"/sens ors/94:34:69:ff:fe:5d:09:49-01-1000/state/lastupdated","operator":"dx"},{"addres s":"/groups/3/state/any_on","operator":"eq","value":false}]
15:43:20:197 DB found rule Rule PUSHDIM_ON 8
15:43:20:197 Sqlite rules: rid = 9
15:43:20:197 Sqlite rules: name = Rule PUSHDIM_OFF
15:43:20:197 Sqlite rules: etag = "97fd6bb418606d4b9ed1213a0fbf4c13"
15:43:20:197 Sqlite rules: actions = [{"address":"/groups/3/action","body":{"on" :false},"method":"PUT"}]
15:43:20:197 Sqlite rules: conditions = [{"address":"/sensors/94:34:69:ff:fe:5d: 09:49-01-1000/state/buttonevent","operator":"eq","value":1002},{"address":"/sens ors/94:34:69:ff:fe:5d:09:49-01-1000/state/lastupdated","operator":"dx"},{"addres s":"/groups/3/state/any_on","operator":"eq","value":true}]
15:43:20:197 DB found rule Rule PUSHDIM_OFF 9
15:43:20:197 Sqlite rules: rid = 10
15:43:20:197 Sqlite rules: name = Rule PUSHDIM_START_UP
15:43:20:197 Sqlite rules: actions = [{"address":"/groups/3/action","body":{"bri _inc":254,"transitiontime":45},"method":"PUT"},{"address":"/sensors/17/state/"," body":{"flag":false},"method":"PUT"}]
15:43:20:197 Sqlite rules: conditions = [{"address":"/sensors/94:34:69:ff:fe:5d: 09:49-01-1000/state/buttonevent","operator":"eq","value":1001},{"address":"/sens ors/94:34:69:ff:fe:5d:09:49-01-1000/state/buttonevent","operator":"dx"},{"addres s":"/sensors/17/state/flag","operator":"eq","value":true}]
15:43:20:198 Sqlite rules: periodic = 0
15:43:20:198 DB found rule Rule PUSHDIM_START_UP 10
15:43:20:198 Sqlite rules: rid = 11
15:43:20:198 Sqlite rules: name = Rule PUSHDIM_STOP
15:43:20:198 Sqlite rules: created = 2022-11-03T21:21:30
15:43:20:198 Sqlite rules: etag = "97fd6bb418606d4b9ed1213a0fbf4c13"
15:43:20:198 Sqlite rules: lasttriggered = none
15:43:20:198 Sqlite rules: owner = 7CA421C07A
15:43:20:198 Sqlite rules: status = enabled
15:43:20:198 Sqlite rules: timestriggered = 0
15:43:20:198 Sqlite rules: actions = [{"address":"/groups/3/action","body":{"bri _inc":0},"method":"PUT"}]
15:43:20:198 Sqlite rules: conditions = [{"address":"/sensors/94:34:69:ff:fe:5d: 09:49-01-1000/state/buttonevent","operator":"eq","value":1003},{"address":"/sens ors/94:34:69:ff:fe:5d:09:49-01-1000/state/lastupdated","operator":"dx"}]
15:43:20:198 DB found rule Rule PUSHDIM_STOP 11
15:43:20:198 Sqlite rules: rid = 12
15:43:20:198 Sqlite rules: name = Rule PUSHDIM_START_DOWN
